THat's 6 *series* cells, yours are 7 *parallel* cells.
To use your charger to charge a single row of those parallel cells, you will only use the main negative and positive wires, and if necessary (probably not) the very bottom wire of the balance.
The main negative wire goes on the negative side of the cell group you want to recharge, and the positive wire on the positive side.
Then you set the charger for "1s" "li-ion" or "li-po", will probably say it's for "3.7v". If it has a charge rate setting (amps) I'd set the very lowest setting it can go to.
But if those are really at 0v, you should not charge them, you should replace the row. Even if they recover they probably will not be the same as they had been, and there is a risk of fire for cells that are below their minimum voltage, especially since you don't know *why* they are drained down. If they are at 0V because there is one that is internally shorted, then recharging them could either directly overheat that cell, or it could heat that one a bit while charging the rest, and then it could quickly drain all that charge out of the others, heating it further. What happens after that depends on what's wrong inside it and how hot it actually gets. :/
It's also possible nothing will happen, but the risk is there.
That's the reason BMSes in general won't allow recharge after a cell drops below a certain point.
Now, if the cells are not actually at 0V, and are just a bit below 3v, and the BMS has cutoff to protect them, then you could probably safely recharge them.
