Kingfish
Greetings –
I would like to map out the IRFP4110 MOSFET to SPICE. I am using LTSpice, however the definition is not available. Instead – I borrowed another component within the library that is similar and reverse the model back to map with the spec sheet and kindly ask The Forum to check my work. In this manner I hope to map out other components as well and post them here.
IRFP4668PbF
SPICE Model
VDMOS – How can I determine the device is of this type from the spec sheet? Is it by virtue of the schematic symbol?
Mapping to the Spec: SPICE Id -> Spec Id (LTSpice definition and other notes)
? = I don’t know how to map this to the Spec.
Notes:
I apologize for my noobness but the mapping just isn’t straight-forward. Are some of these values calculated?
Thanks, KF
IRFP4668PbF
SPICE Model
Code:
.model IRFP4668 VDMOS(Rg=2 Vto=4.85 Rd=1m Rs=1m Rb=1.2m Kp=33 lambda=0.01 Cgs=8n Cgdmin=500p Cgdmax=1n Cjo=4n Is=2n mfg=International_Rectifier Vds=200 Ron=8m Qg=161n)
Code:
Rg = Rg (1, Gate ohmic resistance)
Vto = ? (Threshold voltage)
Rd = ? (Drain ohmic resistance)
Rs = ? (Source ohmic resistance)
Rb = ? (Body diode ohmic resistance)
Kp = ? (Transconductance parameter)
Lambda = ? (Channel-length modulation)
Cgs = ? (Gate-source capacitance)
Cgdmin = ? (Minimum non-linear G-D capacitance)
Cgdmax = ? (Maximum non-linear G-D capacitance)
Cjo = ? (Zero-bias body diode junction capacitance)
Is = Is (1, 2, Body diode saturation current)
Mfr = given: Name of Manufacturer (Note that spaces are replaced with underscores)
Vds = Vdss (Drain-source voltage rating)
Ron = Rds(on) (Nominal on resistance)
Qg = Qg (Nominal gate charge required to get to Ron)
- SPICE value does not match the Spec.
- Units do not match.
Thanks, KF
