I‘ve been commuting with this hub for about 9 months and covered about 3000km.
I‘m 188cm and a bit over100kg with a backpack on. About half my commute is hilly, the flat section typically has head and tail winds.
Its built into a 700c x 25 wheel running 43 tooth chainring and 19 tooth cog, giving about 60 gear inches in low and 82 in high. This is only just low enough to prevent stalling on the steepest hill, and when in top it still gives a comfortable cadence when keeping up with 95% of road bikes.
I‘ve removed the sram sticker so everybody thinks its singlespeed.
I‘ve adjusted the spring so that a comfortable cadence can be maintained in low with it only changing when cadence is quite fast, resulting in a comfortable cadence in top once changed rather than hitting a brick wall.
I find these ratios to be perfect just about all the time. If it had a third ratio, maybe I‘d make low slightly lower, keep high the same, and have another gear in the middle.
It does change up when riding over bumps in low at a cadence near the shift point, and won‘t change down while there is load on the pedals. Easing off lets it change down, or I might stand and accelerate depending on whats ahead. I don‘t find this to be a big problem.
Originally when I built the wheel I didn‘t use spoke washers. I broke a spoke after a couple of weeks. With the addition of washers the spokes are now pulled up hard against the hub flanges. No more have broken, although I‘m not using the hub brake much and never hard anymore.
I really like this hub, and so do my knees, probably as I‘m out of the saddle for all the steeper hills, and spinning fast on the flat with not much load. Its nice not to have to think about changing gear, just stand or sit. I‘ll continue to use it in preference to my multispeed bike. Theres also much less maintainance, 8 speed chain lasts me at least 4 times longer than 9 speed, and there are no cables that stretch/break or derailurers that need adjustment.
