rollingreenhills
1 W
I have googled the living whatsit out of this. . .
Can you use a step up transformer in the following circumstance.
2 x 12v 22ah Panasonic SLA linked in serial to run this transformer:
http://www.ebay.co.uk/itm/281755037627?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Specs say "24V * 20A = 480W", so I am expecting the motor to be underpowered, but by how much do you think?
The motor is a 500w 48v bafang BPM. It is a 230 rpm model in 20" wheel. I am upgrading from a unite 1020z chain drive, which had nearly zero torque.
When these SLA batteries die I will get some lithium battery, but I would like to use them, rather than get shot of them, perhaps that is unrealistic.
Best Regards W . .
Oh! I recived the following info from handy chap on Google Plus called Jim Conner:
Hi +kermit green - I didn't know that a 1200W version was out there... I might have to order one of those for myself.. for a little project I've been playung around with for which I have not yet made a video. The specs on the 1200W unit (if you're buying the same one I'm looking at) seem a little confused though... They say that it's limited to 20A input current (which would mean that on 24V the max you could get out of it would be 480W), and then they say that it has a 30A fuse on there (which would let you pull 720W max from 24V)... This might give you some problems running a 500W motor, as the 500W rating will be the continous-power rating for the hub motor, rather than the maximum peak power it can pull (which is probably over a kilowatt)... On my own 250W motored bike, I've seen the motor pulling around 850W peak power. I wouldn't worry too much about damaging the converter... as long as you don't connect the input power the wrong way around, or directly short-curciut the output, it should be pretty much bullet-proof.
Anyway... onto the current limit... The biggest problem with the current limit is working out which way to turn the screw to get it to maximum power. When I have set up my own units in the past, I've used a string of low-voltage light bulbs (either 12V car lights, or a string of fairy lights) so that I can twiddle the amp control and work out of the lights are getting brighter or dimmer. Once you work out which way gets brighter, wind it all the way up to maximum - You don't really want to limit the current you're supplying to the motor.
Hope that helps - ping me again if you need more help or a better explanation. Cheers!!
Best Regards W . .
