Yes, I love anodized parts as well! If I can find a good contact for anodizing I would definitely do some pieces. This company is going to powder coat anything I want for free (sticker on my bike) :-D
@GITtech I rewound the motor for 88kv and it will be 12s lipo 48volt. The first stage reduction is 10:1. The second stage is the Nuvinci CVT. In the lowest gear it can do 2:1 so the overall ratio is 10*2=20:1. The shift map is tuned right now to hold the motor at 3000 rpm. 0-11mph will happen from 0-3000 motor rpm. Past 11mph the Nuvinci begins to upshift holding the motor at 3000 rpm constant. As you approach the end limits of the CVT the efficiency reduces. There will be a point where it is more advantageous for the motor to begin climbing past 3000 rpm to its 4200rpm max rpm. This is going to be tuned into the shift map :-D gotta love getting to program your drive train to do anything you want it to.
I am building the bike for mainly street usage so I am not concerned about the unsprung weight. I am actually excited to have the weight that low. I expect the entire swing arm assembly to come in >40lbs. This is less than half the weight of a 50cc-150cc gas scooter swing arm, motor, cvt, combo. I am using Turnigy hardcase packs that are supposedly ready for abuse. I will also be mounting them in the swing arm with energy absorbing foam under them.
This is the padding I use. Adhesive on one side foam on the other. They work great!
