Alan B
Nice battery friendly dual suspension frame. Need more options like this.
monkeychops said:I've got a similar bike which I'm slowly upgrading.
I'd be interested to know what kind of torque plate / torque arm you use and whether you re-use the rear disc brake.
Also wondering where I can get a 16s4p a123 battery if it would fit inside the stock battery case...
monkeychops said:I have sent doctorbass a PM. I'm thinking that with his derailleur attachment ones I won't need to do any glueing or welding. Not that I could do any welding anyway...
...I have a thread going already with lots of noob questions and mistakes etc. I will add more photos from now on - from yours and others it really helps and is loads more interesting to have photos. It's here http://endless-sphere.com/forums/viewtopic.php?f=3&t=32898
How does the MPII compare to X5305 in kv?neptronix said:Pie II on 36S2P is going to be stupid fast.
20S2P will already beat all the local high powered motorcycles i've encountered out here, and geometry / wheelies with a 26in. wheel in the front has became a serious prob.
You might actually have really good results with a Crystalyte HT in a 20in. rim. There is certainly a lot more magnet and copper in those motors, and the diameter isn't all too different.
If you have the means, you may want to lean towards that direction. It'd be something i would experiment with, personally.
The tradeoff might be worse heat dissipation however.
Good luck. You have a great chassis there. I wish i could get my hands on one of those - it's a poor man's stealth bike, imho.
monkeychops said:Like the metal box. It looks a really good fit.
Will you have the controller underneath in this configuration as well?
Looks like nicobie found a source!nicobie said:I wonder where a guy could find one of those?
shock said:Cool build! I like the look of the DIY aluminum box. I would fill that with LiPos and be done with it.
My Question is why 20" wheels and not 26"?
Brentis said:shock said:Cool build! I like the look of the DIY aluminum box. I would fill that with LiPos and be done with it.
First.
I likes me some torque. :wink:
Given equal volts/amps, a 20" wheel will have more torque/less speed than a 26" wheel.
It should also run cooler/ be easier on controllers.
Second
I am looking to build something closer to a moped than a bike.
So a tire upgrade seems prudent.
16" moped tires just happen to fit 20" bicycle rims.
Third
I think it looks kool. :wink:
There are other reasons, but I am writing this on an iPhone, and my patience with this format just ran out.
Stay tuned...
