Hello everyone,
My drive system worked flawlessly for a few weeks, but suddenly I came across an issue that made my electric scooter unridable.
*btw I wanted to post this in the E-Bike section because i have seen more similar issues here so this will more likely help someone else as well and the tech is very similar.
Here is the problem:
When I increase the current my hub motor (not geared, rated for 350W and 800kv, running on 48V) starts vibrating so strong that it can not accelerate the scooter, even when the scooter is moving. Without any load it is at least able to start and reach max RPM. If i increase the current too much, the motor lurches and the VESC (Version 4.12) cuts the throttle.
First I assumed that it was an issue with the hall sensors, so I checked them all and found that when the wheel is rotating they all change from 5V to 1,87V, none of them had a constant voltage.
I wonder whether its a problem that they dont change from 5V to 0V. But the motor has a significantly better starting performance without stuttering when the hall sensors are connected and the VESC always detects all 3 of them without showing any issues.
My ADC throttle input is nice and linear, thats not causing the issue.
The motor wires are connected firmly and are not damaged.
The problem occurs in BLDC and FOC pretty much the same way, I am using the exact same values as before when it used to work.
I have thought about this and tested the whole day but I just cant find a solution.
I would really appreciate any help or thoughts you have on this!!
If I should give more details about something please tell me.(if needed also in form of photos/videos)
Thanks!
Thanks!
