Hi,
I'm the friend of TheBeastie whose bike motor is doing the stuttering
Thanks Shorza for suggestion of checking the hall/phase combo, I will confer with TheBeastie and see what he reckons.
The bike's been working awesomely for 6 months,
thanks to Kepler's awesome skillz
However the stuttering has occurred a handful of times in the past, and when I first asked the original bike owner about it (the dude who build the bike), he said "check the green wire".
So in the past I just unplugged and replugged the green wire half a dozen times until the bike was all humming along nice and smooth once again.
"The green wire" is one of the main power wires that goes to the motor.
I think it's some kind of semi-broken wire connection somewhere... not sure if it's "the green wire" or not, but I suspect it is.
What's happened recently that disturbed the wiring, is my ebike was serviced by the local bike shop, and they took the back wheel off as part to the service (changed a flat the rear tube that could not be repaired any more). And the bike really needed a major service anyway and they did a great job, new brakes, tightened everything that was getting loose. But yeah I noticed the cabling had been moved (unavoidable when taking the back wheel off)
As I left the shop the motor stuttering was already back again. So I stopped and unplugged and replugged the power wires but the stuttering was still there.
Rode back to my office and halfway there the power just kicked back in full bore again, by itself, so I was happy.
Leaving work that evening, full smooth power was available for 5 minutes, until I jumped a gutter and the power cut out totally and the best I could get it back to was the stuttering effect.
So the wiring has been upset somehow, as evidenced by the intermittent changing from [no power / stuttering power / full power]
The current situation now is always stuttering, and interestingly... while testing, with the rear wheel up in the air, sometimes when putting the throttle on, the motor does not have any power at all until I move the back wheel slightly and then it starts again, but still just powered stuttering.
I'm a bit of an electronics neophyte, and TheBeastie is more tech savvy than me (built his own ebike) but we are not electrical engineers and not really sure exactly where to start looking, so posting here for some more suggestions and clues.
It seems to be the wiring, just how to figure out where the break/loose connection is, and how to go about diagnose it is where we are currently baffled.
The powered stuttering does still have some good torque behind it (e.g. going up a hill slowly) but just very slow maximum speed.
Our only other thought was the motor has somehow
