Karolis
I think it is only good for recycle. The contacts were cut for not to use those cells any more.
cell_man said:As was mentioned I'm kind of sold out of 20Ah cells. That's not strictly true, I have a customer that has already purchased a big quantity who is due to take most of the remaining 20Ah cells.
cell_man said:As was mentioned I'm kind of sold out of 20Ah cells. That's not strictly true, I have a customer that has already purchased a big quantity who is due to take most of the remaining 20Ah cells. With what's left I could probably do some smaller packs but not sure I'd have enough for a bigger pack. Situation on the 15Ah cells is similar but have a few more 15Ah cells to spare. There's no news on more batches of cells at the moment.
cell_man said:I believe it's for a BMC V3 1000W setup so max 50A, probably a bit less.
cell_man said:I thought you were going to have 2 facing the other direction? If that's the case, then it might be easier to terminate if you have 2 of the 8 packs assembled with terminals on the opposite side from the other 6. You'll need to allow some space for the termination onto the terminals as well, so this might add some additional length on that side. It's no extra work to assemble the pack in either configuration but it's a big job to change it once it's built.
