flip_normal
As I understand it steel and aluminium have a tendency to electrolyse when in contact with each other, especially in humid conditions, and eventually produce a high resistance connection. You could use adhesive kapton tape on the outside faces of the tabs and solder the balance wires directly to the tabs. I like the simplicity of disassembly offered by this method, as long as the clips are supported to prevent stress on the tabs this would probably be my preferred method of connection.peterperkins said:Could we use a special sort of very stong bulldog clip to clip cell tabs together?
Some sort of machine spring clip with flat faces and a special tool to spring it open and release it onto tabs when in position.
BMS wires can be soldered to the clip or have a 1/4" spade terminal built into clip.
EDIT: The balance wires could be terminated with an aluminium strip and the tabs folded with the strip slipped into the sandwich prior to the clip being attached, thus avoiding any soldering to the tabs. Support could be provided by a sheet high density foam with rectangular holes cut out for the clips to recess into.
