teslanv
I picked up this frame from my local Craigslist yesterday.
I was pleasantly surprised at how beefy this frame is, considering it's weight.
As many of you know, the Giant DH frames are one of the best frames to build a high-performance ebike with, due to the superior rear suspension design and large triangle space for a battery.
Now I'm trying to decide what kind of system to install on it.
Thus begins my quest to build the ultimate off-road Ebike.
My requirements are:
Power of about ~3000W-5000W Mid Drive if at all possible. (Will be looking at the LR Options, probably, or maybe one of the New Cyclones.) The Frame & Rear Suspension system take up a bit more space around the Bottom Bracket (100mm wide) so I am not sure what systems will fit without some modifications...
Light-Weight and agile for superior off-road/trail riding. - (I would like to keep the weight in the center, with a Mid-Drive.)
Probably a LiPo Battery. Range is not as critical as is current discharge capability. Probably Nano-tech in the 18S Voltage range.
IGH. I am hoping the Shimano Nexus 3-speed IGH I have kicking around will be able to handle the Power of the motor kit I choose. Your experiences with a Nexus 3-Speed IGH is greatly appreciated, or other lightweight alternatives???
The Nexus IGH has three ratios, .733, 1, 1.364 which multiply the cog count of the single speed freewheel that mounts to the hub. If I Use an 20T Freewheel, I can get an effective tooth count of 14T, 20T and 27T, which should be enough range to do what I need on the trails, exspecially considering the power available.
DH Fork, Double Crown, like a Marzocchi Bomber or similar.
Probably 26" Bicycle (Downhill) Rims & Maxxis Holy Roller Tires, to keep the weight to a minimum.
Let the research begin. 8)
