gameofbikes
1 W
So I installed the bbs02 and got the calibike 48V15Ah battery. I got a trunk bag for the battery and a rear racck, but the day that i put it all together I found that the wires were too short to reach each other (from motor to the discharge cables on the battery). I hooked them up anyway, the connection barely made it, and the wires were very taught (no slack at all). But I was so eager to try it out I wet for a short test ride to see if everything worked. Good news, it worked. Bad news, after a minor bump (about 30 seconds into the ride) the red wires became disconnected. I thought nothig of it. Put everything away until i could splice some extensions to solve that wire length issue. Not sure if this matters, but the wires in the battery and the wire I got from the hardware store seemed very different. THe wire from the battery had a hug enumber of very fine strands that were silver colored. THe one that I spliced in was much thicker strands that are copper colored.
I spliced in some 12AWG wire bought from the hardware store (strip ~1.5" insulation from each end, twist together, solder together, heatshrink). Hooked it all back up and the bafang system now will not turn on. Pressing the power button does nothing. The calibike battery has a little switch with an LED, but I can't remember if the LED ever came on (it doesn't now). I double checked everything and I have no idea how I did something this colossally stupid, but I noticed that I spliced the wrong colors onto the battery's discharge wires! (red to black and black to red). How on earth I did that, i have no idea. I specifically remember taking the colors and matching them up before beginning to solder, but I must have spaced out and frocked up the only thing I could have frocked up at that point. But after switching the wires back to what they should be the system still doesn't power on.
So I'm thinking either the system broke when I hit the bump and the wires disconnected, or i damaged the battery when I tried to turn the system on with the wires crossed. The latter seems more likely.
I'm not seeing any indication from the charger that the battery is "alive", though it was fully charged before i took the 30 second test ride, so should still theoretically be 99.9% charged. I don't know what the lights on the charger represent anyway, but the lights stay the same right now regardless if the battery is connected, and regardless if the battery's switch is flipped on/off.
What do you all think? I've contacted Rafe (calibike owner) with this info, and ordered a 2nd battery from him (would be great to own a spare anyway, if I can get this first one working again). But it seems like he is a hard person to get a hold of based on feedback I've read about people trying to get help from him. What are some basic diagnostics I should run to narrow down the problem? What tools will I need for the test(s)? Please be as detailed as possible, as I haven't taken an electronics course before, and am pretty new to electronics and motors. I'm willing to take the battery apart to test things, find out if the BMS is broken, etc, with your guidance.
UPDATE:
Feb 02, 2015
I contacted Rafe, the guy who runs calibike.com and explained the situation with my battery and included a link to this thread. Literally, within 30 seconds of me hitting send, I received a phone call from him. I really appreciate that very fast response from him.
Basically he is going to send me a new BMS and new heatshrink sleeving, and also a link to a fuse that he recommends I install between the battery pack and my motor/controller. He said that he sent an email to owners of his battery with info about the fuse, but I never got it. I don't know if I ever provided my email address while ordering the battery so I wouldn't fault him for that. But it might be a good idea for him to post info about the fuse on his website.
Anyway, this is good news to me. I will probably come back here again seeking advice on replacing the BMS. Rafe said that I will have to solder 3 wires, which I don't think should be a problem. If anyone reading is in the Bay Area and would like to help me out in person when the time comes, i'll be happy to buy you lunch and/or a 6-pack of your favorite beverage! (PM me).
UPDATE:
Feb 02, 2015
