bchaney
Hey guys, I just installed my MAC 350w with BMS Battery 48v battery and integrated 18A sine wave controller (https://bmsbattery.com/ebike-battery/774-48v116ah-case-08-bottle-panasonic-battery-pack-battery.html), and I'm getting some strange behavior from the throttle. The motor power "cuts out" at certain throttle position. The position varies... it seems like if I gradually increase the throttle it will cut out at a higher speed than if I floor it. If I push the throttle to a certain point, the motor will accelerate to that point and then the power will cut out - it will not maintain speed. I have to return the throttle to 0 and then push it again to get any power. Not sure if this is making sense, I could take a video if it doesn't
I have checked my P and C parameters and can't find anything that seems wrong. I checked the throttle voltage output and it seems to be correct, it varies from about 0.8v to about 3.8v depending on throttle position. If I hold the throttle at full it is outputting 3.8v but the motor stops getting power. This makes me think it's a controller/parameter issue.
Max speed is set to 72mph
P1 = 16poles x gear reduction of 5 = 80
P2 = 0
P3 = 0
P4 = 0
P5 = 0
C1 = 06
C2 = 0
C3 = 2
C4 = 0
C5 = 10
C6 = 3
C7 = 0
C8 = 0
C9 = 0
C10 = n
C11 = 0
C12 = 4
C13 = 0
C14 = 2
P2 = 0
P3 = 0
P4 = 0
P5 = 0
C1 = 06
C2 = 0
C3 = 2
C4 = 0
C5 = 10
C6 = 3
C7 = 0
C8 = 0
C9 = 0
C10 = n
C11 = 0
C12 = 4
C13 = 0
C14 = 2
