skeetab5780
This is a new winter build I threw together while anxiously anticipating the warm weather. This thing is a little wheelie machine at 84volts 45amps powered by my 18650 Dewalt Sanyo battery packs. (20s 6ah) I had them temporarily mounted inside the triangle with zip ties, but took them out to rebuild them so they fit better! I may mount them under the bottom tube of the frame next, I'm not sure. I have completely soldered the wiring from the motor to the controller so that's not going anywhere. I also opened up the lyen controller and took all the unnecessary(not used) wiring dongles out of the controller to reduce wire clutter.
Primarily I made this bike as a little "trick" bike to rip around locally or in my warehouse at my work. Take it to the skateboard park on the weekends, ride some wheelies. Now its a commuter
At first I had a 152mm crank on the bike and almost killed myself on a corner when the pedals hit the ground from low clearances due to the bike being a 26" MTB frame. I put the 140mm on and now its great fun, this little bike is so easy to whip around.
Big thanks to RallySTX for the hub motor at a good price
And whoever sold me this entire S-750 Tidalforce complete new bike on Ebay for $75.00 shipped 2-3 years ago
Bike Components:
Frame: Tidalforce S-750 (Shaved off brake bosses)
Fork: 26" Manitou Black elite
Tires: 20" x 1.95" street
Motor: 20" 9 Continents 9x7
Controller: Lyen 12-fet 4110 45a
Throttle: 48v Golden motor Thumb throttle
Front wheel: 20" Disc ready from Calhoun Cycles
Kickstand: Greenfield Aluminum
Crank: 140mm Origin 8 pro 110bcd
Chain wheel: 110bcd Sins Aluminum blue anodized
Headset: FSA Sealed 1 1/8" Threadless
Stem: DK bikes 1 1/8" Threadless
Bars: Primo Moe BMX bars blue
Grips: Downhill lock-on type red/black
Brakes: Avid Promax W/ Avid levers and 205mm rotors
Seat: WTB Speed V (I put this on every bike)
Chain tensioner: God Speed
Torque arms: NOT INSTALLED
Bike Components:
