HAL9000v2.0
THis is my latest but most PITA build so far. It looked simple when lady next door asked if I can make her Kona electric. I wasn't suspicious even when she told me that she was in local ebike shop and they told her the bike is to small for all boxes they have. So after few weeks here it is: Small 17" Kona cinder cone with 48V10Ah +controller+bms inside frame triangle. Yes some grinding off headways was needed but only 3mm from minus pole..
There are only two wires one from motor and one from throtle. (I have to make some custom throtle too because of rapid fire shifters)
Box is made from 0,8mm thick (~PI/100" <--- for those who don't speak metric ) high tensile steel. Find attached dxf files of thr box. You can easy cut it from steel plate then bend at 45° by all lines, some small welding at the corneers, drill holes, paint and voila....
[youtube]3YFRQ0MYFrE[/youtube]
Files description:
Kutija.dxf - cutting line for box
Poklopac.dxf - cutting line for cover
Kutija-linije-piganja.dxf - bending lines for box
Poklopac-linije-piganja.dxf - bending lines for cover
Files description:
