knightmb said:Miles said:I think it's really up to the makers of hub motors to provide something better to fix a torque arm to....
I agree completely. Unless you really lock washer the crap out of it, the defaults provided are not close to enough for anything over 36 volts (maybe 24 for some hub motors with a lot more toque)
In my pictures at the beginning, I'm using over sized lock bolts for more grip area, double flat washers on the outside of the fork arm and the torque arm you'll notice is on the inside near the motor instead of the outside for more leverage control. The motor is also a 406, so it's not a low end torque monster to further help negate an axial spin from a stop.
I'm a little unclear on the order of washers/lockwashers etc....
How does it go exactly from left to right? Did you have to spread the fork with all that sandwiched in there?
Is it like this? (from left to right)
Nut/lockwasher/washer/dropout/extra washer /extra lockwasher/ hubmotor /extra lock washer/extra washer/ torque arm/ dropout/ washer/lock washer /nut
Was the axel keyway in the way of any of this?
