johnnyz
Hi there
I initially started this as another post. I bought a new ebike (Motorino XMR), and decided to modify it. I started with the batteries, pulling the SLA's out of it (72 volt 6 sla =100 lbs)
This saved about 75 lbs when I put 24 Headway cells. The bike pulled much better and gained another 3-5 kms per hour. ( 55 KPH with SLA, 60 kph with Lifepo4).
I decided to swap out the stock controller for my Crystalyte unit which can pull 65 amps. All hall and Phase wires were the same color.
Before hooking up the Crystalyte controller I plumbed in a 5 amp fuse between it and the controller. When I set the breaker in the bike it kept blowing fuses.
I attributed this to the capacitors in the controller, so changed to a 35 amp fuse. All well...light came on the controller and the Cycle analyist was working.
I then decided to test the stock throttle with the wires in the controller. Got the Positive, Negative and signal wire from the C Controller (Black=negative Yellow positive and Green=signal). When I hooked up the red wire from the throttle to yellow on controller and black on the throttle to black on the controller I got 4.8 volts. So far so good...there were 2 more wires from the throttle wiring...one purple and one grey. When I hooked up the purple and twisted the throttle nothing happened...when I twisted the throttle with the grey it changed from 2.04 to 2.07 volts..I hooked it all up getting color sequence halls from C Controller to the halls going to motor and color coded phase wires to phase coming out of controller. Turned on power and then turned on controller...nothing at first and then half twistand motor runs smooth but stops..then when I released the throttle...it would run for sec and then stop and then repeat..
I decided to test my Crytalyte throttle with the controller and of course when the signal wire was probed the voltage changed from 2.5 to 3.5 when I twisted the throttle. I decided to test all combinations of halls and phase wires with my C throttle. After 3 hours...nothing...no combination worked..
If anyone has any ideas they would be greatly appreciated...This bike uses a sine wave controller and so my question would be is the motor not compatible with the Crystalyte controller??...not sure whats happening here..
NOTE:...Heres a pic of the inside of the throttle...could this have anything to do with it?
Thanks
John
Thanks
John
