Hi !
First a small introduction:
My name is Niels and live in the Netherlands.
I'm 29 years old, father of two, and studying administrative law at the UVT.
My interst in electric powerd vehicles started with an electric powerd boat.
8,5 meters long, 140 years old, with 2x 1650ah battery and a 48 volt - 7kw electromotor, on witch I occasinaly
do tours with people in our canal. (in the pic it's me, my father and my two children).
Now it started with an idea to convert my old carbon peugeot race bike into an electric powerd bike with an friction
drive, to reduce weight and make easy changes in the setup. I believe it is called the kepler system(?).
Now I started out, very boldly, by ordering some components:
- 2x 3700mah 5s 18,5v lipo and safety packaging
- a charger and a 12v 28A power supply (LED driver)
- and the most imported one! a Turnigy aerodrive motor, 192kv 2750watt 80A max
http://www.hobbyking.com/hobbyking/store/__18129__Turnigy_Aerodrive_SK3_6374_192kv_Brushless_Outrunner_Motor.html
I still need a servo tester wich I will convert to throttle control, and an ESC.
Now my question is, what would be the best setup for my motor (and lipo pack in series or parallel)
My main difficulty is finding the right (not to expensive) ESC.
I am wondering if I put my 5s lipo's in parralel, creating 7400mah at 18,5 gives me enough to enjoy this motor, also it would give me a cheaper ESC, the 10s/12s ones are very expensive.
If I calculate the right ESC with this setup i get : 2750watt motor / 18,5v = 148 Amp, but I don't understand how I can drain more amps than the 80A Max on my motor??? what am I doing wrong?
Also, what kind of ESC is mostly used? With BEC seems more handy to me, because my servo tester will have power from the ESC rather than OPTO where I will have to provide my servo tester with a spare battery or UBEC.
Now, I'm really new at this, and R/C, so my kwoledge is currently based on reading a lot on this site and R/C sites.
I really hope you can help me out!
Greetings,
Niels
Greetings,
Niels
