shortcircuit911
Hey Everybody, I bought a turnigy 80-100b motor and added hall sensors to it with no problem. When I run the motor with no load the motor spins up all the way. When I hook the motor to the chain with the wheel off the ground it will spin to 3/4 then cut off. If I try and put full load on the wheel the motor comes on for a second then cuts off. I checked the halls and they seem fine. I also hooked up a volt meter, and the voltage stayed at 38v even when the motor cut off. Then I hooked up 44v of lipo and it did the same thing. I tried all 36 different wiring combinations, and only this one works. I'm really out of ideas, and am hoping someone can help me out. Any advice would be much appreciated.
