Reid_in_QC
100 µW
- Joined
- Oct 31, 2021
- Messages
- 8
Hi I have a pair of brand new 170mm dia. single shaft hub motors from UUmotor and a matched 2x50A 2-channel controller to drive them both.
MOTORS
• UUMotor model SV8H, ordered direct from mfr in 2023
• wound for low speed, high torque and suitable for use with 24-60V battery packs
• 120Nm peak torque at 35A
• ≈ 250rpm at 48V
• 4-bolt wheel mount on 100mm bolt circle
CONTROLLER
• 2 channel controller from UUMotor drives both motors
• 40A cont 50A peak. 18-60V.
• CAN/RS485/RS232, Hall, A/B/Z or A/B+H sensors/encoder
These were purchased for a prototype but not used.
Located outside Montreal. Will ship within Canada for real shipping cost.
full specs at the following URLs:
MOTORS
• ≈ 250rpm at 48V
CONTROLLER
120n.m 17 inch 1000w servo hub motor with encoder - uumotor
Model: SV8H17Price: USD385 1024PPR 4096CPR high torque 17 inch 1000w tube tractor tire robot hub motor with encoder, the rated torque 70 Nm, max
www.uumotor.com
70-120nm single shaft electric car motor with encoder - UU Motor Retail
48v 1000w robot car hub motor with encoder, the rated torque 70 Nm, max torque 120N.m. It is a single shaft gearless, brushless dc servo hub motor with Magnetoelectric encoder. The rim is removable and 6.5 inch rim, it can be used for different tires and easy to replace the tires. It is good for...
retail.uumotor.com
multi-function RS485 CAN encoder dual control servo motor driver - UU Motor Retail
It is also can be controlled by ADC , which is use throttle to control speed and more interesting function is that this new driver supports RC controller, but you need to buy RC your self. The driver or dual drive controller can control two motors or one motor if you like, and even four motors...
retail.uumotor.com
multi-function RS485 CAN encoder hall sensors brushless dc dual control driver - uumotor
Model: SVD48 Price USD160-180 RS485, RS232, CAN, PWM, analog inputSV-Config programming software, RS232 interface A/B/Z type, A/B+HALL type, Hall
www.uumotor.com
