warrah
For sale, another 66v (nominal) 18s16p 18650 3010wh pack with a 70a ANT programmable BMS and a 10a charger, all wired up. Has only been cycled a handful of times, but has sat on a workshop shelf for a few years so will have lost a bit off its calendar life.
Pack is made from LG INR18650 MG1 cells, arranged in 18s16p configuration. The 16p are divided into two 8p bricks, each measuring 15cmx20cmx21cm with the 6mm pink foam on. These two bricks are then wired in parallel together, which is useful to know if you are trying to get these packs to fit into a certain space.
I can also throw in a 1kw 240VAC inverter for free if you are interested.
£150. Shipping might be tricky but we can look into that, or if you are in the UK we can travel and I can meet you half way for collection.
