markz
100 TW
https://www.mcgill.ca/oss/article/general-science-you-asked/concrete-truth-about-batteries-stored-concrete
https://gelcoservices.com.au/docs/Lead%20Acid%20Battery%20Self-Discharge%20Paper.pdf
The batteries of today, however, are encased in plastic or hard rubber, which significantly reduces this energy waste. Batteries do naturally self-discharge over time, however, but this is due to an internal process, not the type of material on which the battery is sitting.
A compound called lead sulphate naturally forms during battery use and it can crystallize onto the negative plate of the battery, especially when the battery rests for a long time. These crystals end up impeding battery performance over time.
Heat is bad for batteries. According to manufacturer Pacific Power Batteries, a car battery in a hot climate will last, on average, only two thirds as long as it would in a cold climate. For example, a battery that lasts 4 years in a cold environment would only last 2 years and 8 months in a hot climate. Keeping the battery on a slab of concrete, which can act as a heat sink, might actually extend its life by absorbing some of that heat.
And remember that batteries, as a rule, last longer when they’re cool.
The graph shows the fall in specific gravity per day of a new fully charged battery with
6% antimonial lead grids. Self-discharge can thus be minimised by storing batteries at
temperatures between 5 and 15C
