Seems to be a shortage of companies making nimh chargers with temperature cutouts. The only one I know of being the chinese 'highpower' type chargers. I've had mixed results these, some have died, some not. I wondered if drill chargers might work ok for charging nimh so I tried an experiment to see if an old bosch charger I had would work for my nimh packs.
Much to my surprise it was very straightforward. The Bosch batteries use the same thermistor (10K ohms) that came with my nimh packs so it was simply a matter of connecting 3 wire cable to the charger (see pics below). This charger only charges at 1 amp but the temp cutout works fine and the packs fully charger each time. Nice thing is its quite robust as its designed to be kicked around a building site. I've not experemented with anymore drill chargers yet but there's quite a few available for cheapish prices for example this 5 amp charger might make a nice charger for a 48 volt pack (2 x 24v)
http://cgi.ebay.co.uk/Bosch-30-min-Dual-Bay-Battery-Charger-BC230-bluecore_W0QQitemZ130129624837QQihZ003QQcategoryZ20794QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hilti also do a 36 volt charger which occasionally show up on ebay, plus there quite a few more by makita, dewalt etc, most of them charge at 24 volt and up to 8 amps. The other nice thing is they generally charge at a variety of voltages so you can make up packs with non standard numbers of cells.
