calfeetwenty
- Joined
- Aug 12, 2016
- Messages
- 67
Well I have had this kit for nearly a year and I am finally working on it. I pulled the 50mm QS motor off of my Luna cargo after one successful test run and put it on the vector. I was a bit put out about how much filing I had to do to the dropouts to get the axle to fit. I had to remove the swing arm and get it in a vice so that I could take a proper stroke with a file. Personally I don't feel that is something a builder should have to do.
Then I pressed in the headset installed the fork, laced a wheel and added a set of Jones bars.
I am running a 26 X 4.0 fat tire in the rear and a 27.5 X 70mm on the front. This is making the bike quite tall even for me with my long legs. I put a PNW dropper post on it . Unfortunatly I got the long one and I can't put it down all the way because of interference with the top of the rear shock. My rear tire has a diameter of 29". This wouldn't be an issue if I was using a moto tire but I am going to stick with this for now.
I can either use a shorter dropper post or use a shorter rear shock to get the seat height I want. Maybe both will be the way to go. I removed the rear shock and with the aid of my small electric winch I raised and lowered the bike while taking measurements to see how much shock lenght and travel effects seat height. I figured it would be a linear equation and thanks to a frendly math page I got this graph that some people may be interested in.
The left vertical scale is in inches from the floor to the top of the shock mount tab in it's upper position. The lower horizontal scale is millimeters across the eyes of the shock. Your change in inches will be valid anywhere in the seat area of the bike. This last chart is the selection of burner 2 shocks from DNM.
My bike came with a 220 shock with an 850# spring. I have to decide between a 210 or a 200 unit with a 750# spring. 20mm at the shock is about 2 inches at the seat. I can straddle the bike now just forward of the seat with my feet flat on the ground but a little more clearance would be nice.
