hillzofvalp
I am doing a motorcycle conversion.. I'm extending the swing arm and can't choose what the slots should be: vertical or horizontal.
Benefits of vertical:
-Natural wire exit angle
-able to cold set swing arm for vertical alignment (?)
-near impossible for wheel to ever go out of misalignment
-axle always orthogonal to torque plates.
cons: Have to get it perfect the first time!
Benefits of horizontal:
-able to adjust horizontal alignment
-able to adjust wheelbase
cons: there is a chance of stress on the axle from not perfectly orthogonal axle.
Which is best for 15kW 160lb motorcycle? (16mm.. 10mm flat width)
I'm making them out of 3/4"x2" steel. Each side will get a lot of contact.. but that wasn't the original goal. Original frame spacing was 182mm.. and cromotor with spacer is around 150mm.. so I'm filling the voids.
