voicecoils
MitchJi said:Hi,
Nice bike!
Gary has some opinions about the Neu here:
http://endless-sphere.com/forums/viewtopic.php?f=6&t=3904&st=0&sk=t&sd=a&start=435#p98865
http://endless-sphere.com/forums/viewtopic.php?f=6&t=3904&st=0&sk=t&sd=a&start=435#p100963
Can you fit the packs side by side inside the triangle (which would reduce the width)?
Could you put one inside and one below?
Thanks for the links MitchJi, I've read those posts by Gary, good stuff. The Neu 1915 is what I've been looking at, as you may have read earlier.
The battery mock-ups were made off the dimensions specified but I'll have to wait till the real packs are here to know for sure what can and can't fit.
By the mockups, they don't both fit in the triangle in any orientation (although there is space I believe for the cells if they were loose and not in a brick configuration). One inside and one below is probably a workable option. That's how Deecanio had his packs set up IIRC. I'll tape the mockups in that config and post a picture tomorrow morning.
Thanks for stopping buy
