Doing a recumbent e-trailer project which includes carrying some old recycled solar panels, 150 watts at 48 volts (open-circuit voltage is ~80), and want to charge my LiFePO4 20 amp-hour battery which tops out at a 58 volt limit charging.
A charge controller could be used for my needs to optimize the battery. The solar panels were so inexpensive that the cost of a charge controller begins to dominate the project budget. My question is, does it make sense to just use a voltage limiter on charging the LiFePO4 pack, say to 54 or 56 volts and have the I-V curve of the PV ride the ups and downs of battery voltage and clouds to that point? And if yes, does anyone know of a good one with a 10 amp rating? I would include a blocking diode so there would be no reverse flow. Is there a reason why LiFePO4 should be charged to full? I don't see much energy storage above 54 volts anyway. Yes, LiFePO4 has a BMS.
As always, thanks for endless-sphere.
Best Regards,
Energyi
PS: Great discussion on charge controller for such a scenario in this thread https://endless-sphere.com/forums/viewtopic.php?f=2&t=75232&p=1141076; I also found a less expensive charge controller at http://www.ebay.com/itm/SL03-4810A-10A-36V-48V-60V-Wincong-solar-panel-charge-controller-regulator-LCD-/261853354706 which enables a set-point for charging.
Best Regards,
Energyi
