Hello
I had another controller come in for repair I checked it with my meter and it was clear from testing between the blue motor phase and the battery terminal that 2 of the high side fets were stuck on blown if you like.
So i stripped the controller and replaced the fets and the associated high side transistors, I tested the controller it all worked fine, so i screwed it all back together.
However when I tested it again it started up full throttle straight away!! scary!! so i tried another throttle, same thing full throttle again.
I stripped the controller back down and checked the fets tab to the screw holding it in, 2 of the low side blue phase screws were shorting to deck so I fixed that (thinking that was the problem) re assembled the controller again and bang it did it again.
Erm so no to be put off I played with the controller a little, it would stay full speed as soon as it was powered up, however just by chance I moved the throttle lead and it stopped, I then held the lead firmly in this position and tried the throttle, it worked fine to my surprise.
I then examined the throttle lead and it became clear with a bit of DVM work that the lead was shorting inside!!
I stripped back the insulation and sure enough half way down the cable the wiper input was picking up 5volts off a break in the lead, see the attached photos.
not having any more plugs I cut a piece of cable and painstakingly removed all the pins and re crimped and soldered them to a new cable as you can see in the pictures.
I dont know why this controller came in for repair, it may have blown though as someone was frantically trying to stall the motor, scary stuff.
So its worth checking your wiring but more importantly fit an emergency rip cord or something as on little scooters you just wont stop it.
See the pics
This controller is a happy unit again now.
Cheers
Knoxie
See the pics
Cheers
Knoxie
