Dingo2024
Hi, I am in the process of starting my second build using an old Schwin mtb frame which is 7005 alu. The top tube needs to be extended to increase wheelbase and the plan is to use a billet of 7075 (I think) cnc'd headtube. Also need plates welding onto the frame to support batteries and motor mount. The question I have is;
the frame is/has been heat treated but the billet (and plate)is not.... is it best to anneal the frame (and any other heat treated stuff) to return it to a 'soft state' before welding and then reheat treat everything after fabrication
if this is the case what is the temps / timings to anneal 7000 series
any problems joining 7005 to 7075
any suggestions/pointers greatly appreciated
thanks
Ian
thanks
Ian
