Toshi
ultimately i think you'll come to the same conclusions as me: if you want to preserve the backup use of the seattle bus system then you're constrained to a "normal" bike, and that a normal bike doesn't do well with high speeds. if you want to go faster than that i really don't think electricity is there yet, and the gasoline alternatives are compelling once you crack that door open.
that said, if you do want to stick to electric and just want to build up a bike a bit more on the cheap i'd look at off-brand forks such as RST but would avoid expensive current-gen downhill gear. will you run a rear hub? if you're running a front hub then you don't want a 20mm through-axle setup anyway. if you're running a rear hub then you don't want a downhill frame, as the good ones come with a 12mm through-axle setup (rather than a 9mm non-through-axle on standard wheels) and additionally have wider spacing in the 150 to 165 mm range rather than the 135mm that is standard for mountain bikes. then you have the issues of battery mounting… you see why i ended up with a bike that looks how mine looks.
