Got a couple new builds in progress and have mainly finished welding the frame on the one that uses standard bicycle wheels (other don't).
E-shopping for rear free-hubs and/or assembled wheels with same. Intend to use 8-speed cassette (9,10,11 speed chain too thin for my liking 8-speed max number of rear cogs for standard derailer chain use). Normal 26" MTB rear wheel standard 135mm with rear disk brake. Power I'm going to run through the system is in the 1.2-Kw range to be geared low for more torque and less speed, probably a 14-34 tooth spread on the rear cogs topping out at just under 30-mph top speed in the 14t high gear and obviously at lot of torque potential in the low 34t gear.
Don't want to spend more then I have too but want a rear wheel that will get the job done. I hate 32 or less spoke count on wheels and my feelings on low spoke count wheels are not very friendly, 36 spoke count is bare minimum and I've been known to run higher spoke counts when I can do so without paying a huge amount more.
What you guys recommend/discourage along those lines as far as what is out there and available in free-hubs and rear wheels built on them?
Been looking at some of the Halo free-hubs on their main web-site where their second/third level up free-hubs are available in 48 spoke versions in 135mm but have been unable to locate for sale on the internet state-side. Shimano also has some basic models I've been able to find that have at least 36 spoke holes. Keep on running into a massive glut of 32 spoke hole hubs and even 24 spoke hole hubs that are pretty much worthless from my point of view. My feelings on the low spoke counts are very similar to what Sheldon Brown said about them, even more so for e-bike mid-drive builds.
