I'm happily moving along, testing cells at 2c for a friend's pack, and whammo, suddenly, I hit a string of like 20 cells that all test out abysmally.
I check for resting voltage before I start testing, which removes all of the dead cells. Additionally, any cell with a resting voltage under 3.0 v, I write it on the can. That way when I test it I am aware that it will probably not be up to snuff. I test those cells anyway, just to see what happens.
There shouldn't be so many cells testing so poorly (like 0.01 ah) or even less. I suspect something else is going on.
Step 1: test cell at 2c, then recharge and test again at 1c
Result: See graph below:
The 2c test is on the far left. I ran it a few times (with the same cell), and each time it tracked nearly the same, 0.010ah. The long green line is the 1c test, 2.280 ah. Looks pretty good, but let's compare it to some very normal results:
Here I have overlaid test results from a week or so ago. As you can see, the green line from the first graph tracks the "normal" 1C curve, indicating that this cell is in great shape, no undue sag, good capacity, etc.
Step 2: try to eliminate other possible sources of error
I checked the charger, it is putting out 3.65v
I checked the andersons into the CBA, they're tight
I checked the cells coming off the Voltphreaks charger, they are coming off at 3.60-3.69
Step 3: ask for help
What would suddenly cause these results?
Thanks for the help, until I fix this, I'm pretty much dead in the water.
Katou
Katou
