#boosted said:
When I'm on power, the voltage is all over the place. If I take the scooter for a drive, it will go from 5 bars to 3 on the battery Guage, when its fully charged.
By "all over the place", do you mean a voltmeter (or battery bar meter) keeps constantly changing the reading from very high to very low and back, regardless of what you and the scooter are doing at the time? If not, what specifically do you mean?
If you simply mean that while stopped the bar style battery meter stays at 5 bars ("full"?), but when you start moving or keep moving, it drops to 3 bars, that means either:
--your battery is incapable of fully supporting the load the system places on it under the conditions it's being used.
--your battery meter is overly sensitive, or is the wrong voltage range for the battery voltage / chemistry.
Are you riding on flat terrain, with no wind? Or up hills with gusty high winds? Etc.
Are you gently using the throttle, or riding it hard, using full throttle for acceleration, etc, when you see the battery bars drop?
Exact description of sequence of events would be helpful to troubleshooting.
