wesnewell
There are many ways to charge the batteries and keep them in balance. One method would be a 6s charger where you could parallel balance charge them. That will keep all cells in balance with every6 charge. 6s balance chargers start at $20 for a 50W charger and go up from there depending on how fast you want to charge them. With a 50W charger it'll take about 9 hours to fully charge from 100% dod. The faster you want to charge them this way the more the charger will cost. Your 12s2p pack will be 444Wh, but recommended charge rate is 1C, so a 6s 10A charger would charge at that rate. If you added another 3 packs for 15ah, then you could charge at 15A with a charger capable of that, and so forth.adli3381 said:awesome, thanks for the advice, i think i will start with 6 pack of 4s1p and run then 12s2p, and if i need more range, then I can just add 3 more pack to make is 12s3p. any recommend battery charger? and what is monitor voltage good to have? what do i need to check on the battery? or if the voltage on each battery are different how do i fix it?
-Derek
Another way to charge would be with a 48V (adjusted to 50V) power supply with current limiting, and use something like battery medics to balance the individual packs while bulk charging at 50V.
And yet another way would be to get a charger capable of balance charging a 12s pack all at once, like the Hyperion 1420i. You could still use it to charge as paralleled 4s packs or mod the 3 4s balance plugs into 2 6s plugs and balance charge the whole pack in less than 1 hour. This is where using 2 6s packs instead of 3 4s packs in series comes in handy. I paid $179 for my 1420i 2 years ago, but I think you can find them now for ~$130. It will charge up to 20A for 14s pack. Hence 1420. You need 24V 600W to power it too for max output.
So what sounds like a simple question becomes real difficult to answer since there are so many different ways to do it.
On the bike, all you really need is a voltmeter to keep from over discharging the pack I wouldn't run it under 44V resting voltage to insure longer life.
