Where to find switches rated for 60 VDC
Hwy89
Northern Arizona
I have successfully used 12 VDC switches for controller on/off ignition purposes on 58 V systems but that is a control voltage with very little current.
I am now planning to install two DC/DC converters for lights at 7.4 V and for USB accessories at 5V. I want both converters to be switched on the battery side to prevent parasitic drain on the battery. Either of these circuits could see as much as 8 Amps and the switches should be rated accordingly. Where would I find reasonably priced small panel switches rated for 60VDC? Lighted switches would be nice too, but that adds even more complications.
newark.com
Home > Switches & Relays > Switches > Toggle Switches
Filter Applied Contact Voltage DC Nom : Multiple Values
Toggle Switches: 233 Products Found
http://www.newark.com/w/c/switches-relays/switches/toggle-switches?contact-voltage-dc-nom=60v|72v|115v|125v|230v|250v|500v
More at https://www.mouser.com/
Forgot amps. Sorry
Filters Applied Contact Current Max: Multiple Values Contact Voltage DC Nom: Multiple Values
Toggle Switches: 186 Products Found
http://www.newark.com/w/c/switches-relays/switches/toggle-switches?contact-current-max=8a|10a|12a|15a|16a|17a|18a|20a|24a|25a|30a|50a|60a&contact-voltage-dc-nom=72v|115v|125v|230v|250v|500v
Thanks Marty, that worked. It took a while learning to use the filters but I did find a toggle switch rated for 72 VDC. Put a couple pf them on order this morning. Now I just have to figure out where/how to mount them. They are bigger than I had hoped.
