Kiriakos GR said:Note: Not interested for saddle pole with spring (suspension).
Why? I've heard some good reports of the ThudBuster LT and there's the new BodyFloat which looks promising; http://www.cirruscycles.com/
Kiriakos GR said:I think that I located one of my targets which this one is made in Holland and called as LEPPER Primus.
markz said:One seat was worth atleast $120 new. . . .
friendly1uk said:I think you may have a bad saddle dauntless. Leaning forward takes weight off your back and saddle. Unless your seat is like my first, and stops you rotating your pelvis when you lean forward. Making you bend your lower back instead. Causing stiffness.
Dauntless said:DANG! Also known as the ejection saddle.
This line of text gave me three minutes of strong laughs, thanks mate !!
markz said:With my phat 300lb azz, I would and have broken the air and bell easy.
macribs said:markz said:With my phat 300lb azz, I would and have broken the air and bell easy.
Did the stream ride saddle work for you? I am asking cos we are in the same weight class, and I hate to waste cash .
@kariakos - that is why big boys prefer to ride motox rims. No fear of braking.
