Russell
I used to ride my E-bike and use a fairly low amount of power then I got a 48V LiFePO4 battery and my power use went up 46%. I was already using 48V by running my 36V/6Ah Fatpacks in series with a 12V/9Ah SLA so I didn't jump up in voltage. I always pedal with good effort so I can't understand why I use so much more power. I sifted through my ride data to pick out all rides done on the same bike over the same 31 mile course and here's the data.
Bike: Kona Smoke
Motor: 36V Bafang
Battery: 6Ah 36V Fatpack+9Ah SLA
Controller: Infineon 9-FET 15A
Date Spd Wh/mi
8/2 18.0 7.5
8/5 18.0 7.1
8/12 18.0 7.3
8/15 17.3 7.2
8/18 17.9 7.4
8/20 17.5 7.5
8/30 17.7 7.1
8/31 17.7 7.5
9/3 17.9 7.5
9/4 17.8 7.5
9/4 17.8 7.5
9/7 17.7 7.6
12 ride avg speed: 17.8 mph, avg Wh/mi: 7.4
As you can see I was super consistent. I tended to nurse the small battery for the first 20 miles then raise the pace the last 11 miles. Then I got the new battery and with the added capacity I didn't conserve power which increased my average speed a little (0.4 mph) however my power consumption increased far more, 46%! Even on days when I posted a comparable speed to previous results the power consumption was higher.
New 48V/10Ah LiFePO4
Date Spd Wh/mi
9/9 18.7 10.5
9/11 18.8 10.1
9/21 18.2 10.3
9/27 18.3 11.2
9/30 18.9 12.5
10/1 18.3 11.2
10/4 18.5 10.8
10/7 18.1 10.4
10/11 17.8 10.8
10/18 17.0 9.4
10/21 18.3 11.0
10/28 17.5 10.9
12 ride avg speed: 18.2 mph, avg Wh/mi: 10.8
When the hall wiring was damaged in the Bafang I locked the freewheel and switched to a 21A sensorless controller. Power consumption rose some but the weather was getting cold too which always slows me down.
Date Spd Wh/mi
11/20 16.5 10.6
11/21 17.4 12.0
11/22 17.7 11.9
11/28 18.0 12.2
12/1 18.1 13.1
5 ride avg speed: 17.5 mph avg Wh/mi: 12.0
For 2010 I started out with 1 less cell in my LiFePO4 battery (now 15). Here is the data for the last 8 rides covering the same 31 mile course with everything else the same as last fall.
Date Spd Wh/mi
3/23 18.2 10.9
3/24 18.0 11.1
3/29 18.0 11.5
3/31 18.4 11.2
4/1 16.8 9.6
4/4 17.0 10.5
4/5 19.2 11.9
4/11 19.3 12.2
8 ride avg speed: 18.1 mph, avg Wh/mi: 11.1
The power consumption now is only slightly higher (+0.3Wh/mi) with the locked freewheel and 21A controller compared to when the motor freewheeled and I used a 15A controller. This shouldn't be too surprising since I pretty much use the motor all of the time with a light hand on the throttle. However that still leaves me with the question as to why my power consumption rose so much after getting the LiFePO4 battery. Unfortunately I don't have the Fatpacks and SLA's any longer to try them again. I do have a freewheeling 24V geared motor I could try and perhaps with that I can pedal a little more effciently and use the motor a little less however I'm not sure I can ever get back to 7.4 Wh/mi at 17.8 mph :|
-R
Bike: Kona Smoke
Motor: 36V Bafang
Date Spd Wh/mi
8/2 18.0 7.5
8/5 18.0 7.1
8/12 18.0 7.3
8/15 17.3 7.2
8/18 17.9 7.4
8/20 17.5 7.5
8/30 17.7 7.1
8/31 17.7 7.5
9/3 17.9 7.5
9/4 17.8 7.5
9/4 17.8 7.5
9/7 17.7 7.6
Date Spd Wh/mi
9/9 18.7 10.5
9/11 18.8 10.1
9/21 18.2 10.3
9/27 18.3 11.2
9/30 18.9 12.5
10/1 18.3 11.2
10/4 18.5 10.8
10/7 18.1 10.4
10/11 17.8 10.8
10/18 17.0 9.4
10/21 18.3 11.0
10/28 17.5 10.9
Date Spd Wh/mi
11/20 16.5 10.6
11/21 17.4 12.0
11/22 17.7 11.9
11/28 18.0 12.2
12/1 18.1 13.1
Date Spd Wh/mi
3/23 18.2 10.9
3/24 18.0 11.1
3/29 18.0 11.5
3/31 18.4 11.2
4/1 16.8 9.6
4/4 17.0 10.5
4/5 19.2 11.9
4/11 19.3 12.2
-R
