llile
- Joined
- Dec 18, 2010
- Messages
- 457
[strike]I'm looking at this BMS from BMSBattery.com.
I don't see a heat sink int he pictures, but I do see screws where BMS heat sinks are normally attached. Perhaps the sink is removed for the photos? This looks like a good basic unit, good specs, no frills like bluetooth and so on which I don't really need.[/strike]
[EDIT] I just took Flippy's advice and checked out the bluetooth BMS thread here. Well, I never had any idea how much these things would do.
One of my goals might be to reduce my capacity somewhat, in order to increase life, by not charging to full voltage and discharging to full empty. Apparently the right programmable BMS will allow these settings to be changed, balance at less than 4.2 V, low voltage cutoff at maybe 3.0 or 3.1 volts, etc. Now that might well be worth the extra cash.
Some complaints on that thread about unreliable aliexpress vendors. I'm going to peruse the thread a little longer. BMSbattery, whom I kinda trust, has a bluetooth BMS but very little information about what that actually means. Is it a simple battery capacity gauge or a complex way of setting every parameter and measuring the health of the battery? Maybe someone reviews it, so far I've only found one mention of that vendor. Not much more expensive than the one I linked above.
Here's a link to one of the smart BMS vendors mentioned in that thread. This may be a good fit.
