Hi there, Im planning on building a relatively cheap 20s 16ah or 18s 20ah lipo pack for this motor/controller combo;
https://www.aliexpress.com/item/33056354249.html?spm=2114.12010612.8148356.30.543563f84Jjq7c
Now initially i planned to build a 20s pack at 16ah as the controller does handle 84v charged but Im trying to make my pack as simple as possible and reduce cost as much as possible.
for the 20s I was going to use 5 of these 4s packs in series at 16ah (they also "supposedly" have 30-60c rating probably only 20c at most)
offering approx 1184wh? for around £500
https://www.banggood.com/URUAV-14_8V-16000mAh-3060C-4S-Lipo-Battery-XT90-Plug-for-RC-Quadcopter-Agriculture-Drone-Outdoor-Charger-Power-p-1497200.html?akmClientCountry=GB&rmmds=cart_middle_products&cur_warehouse=CN
But after looking for a simple pack I wondered how much difference running 18s would really make?
If the gearing for both 18s and 20s were for the exact same top speed would the higher voltage be more efficient? would I even notice any difference realistically? or am i completely backwards here?
If I go with 18s 20ah I'd only have to use 3 x of these 6s packs however they are only again supposedly 12c but would have approx 1332wh and cost around £485
https://hobbyking.com/en_us/turnigy-high-capacity-battery-20000mah-6s-12c-drone-lipo-pack-xt90.html
I'f anyone could offer any advice that would be great as this will be my first "large" lipo pack.
I'm leaning towards 18s as I'd prefer to keep it simpler unless there are significant disadvantages or I have made some calculation errors here, I pretty sure I have plenty of gear ratio options to run either 18s or 20s to meet my demands and will be balance charging packs individually each time.
Many thanks!
Many thanks!
