theabsurdman
- Joined
- Jul 15, 2022
- Messages
- 16
Hi,
I want to connect 3 identical 6P packs' parallel strings together side-by-side to operate as a larger pack off a single BMS - 2 questions:
1/ would it be sufficient to make the nickel strip connections between packs, illustrated by red lines in the pic below, to just 4 cells out of each 6? Am I right in assuming that the current requirement would be max pack amps divided by the number of cells in each parallel group?
2/ what would be the implications of recruiting cojoined cells into a parallel group using a single cable connection rather than using nickel strips?
Thanks in advance.
Thanks in advance.
