My diy electric longboard so far, parts list sk3 213kv
PracticalProjects   10 W
Re: My diy electric longboard so far, parts list sk3 213kv
Post by PracticalProjects » Apr 25 2015 5:15am
Thanks a lot! Yeah that is a down side. However I would say the cooling is an important thing and I didn't mind cleaning the thing every so often. However if you can get away with limited cooling I will probably do that next time...
AJP0   1 µW
Post by AJP0 » Sep 08 2015 8:32pm
Hi. I don't really know much about this stuff, but from what I understand when you have a motor attached you can't use the longboard like normal because it would be dragging the motor. I don't know if that's correct. My question is, does your board work like normal with the belt attached to the motor, or do you have to you the electric at all times? Thanks.
torqueboards   100 MW
Post by torqueboards » Sep 08 2015 8:45pm
AJP0 wrote:Hi. I don't really know much about this stuff, but from what I understand when you have a motor attached you can't use the longboard like normal because it would be dragging the motor. I don't know if that's correct. My question is, does your board work like normal with the belt attached to the motor, or do you have to you the electric at all times? Thanks.
There is drag. You are also riding with an extra 5-10 lbs of equipment underneath.
But once you ride electric, I don't care for much to kick anymore lol.
DIYElectricSkateboard.com Electric Skateboard Kits
AJP0   1 µW
Post by AJP0 » Sep 08 2015 9:11pm
torqueboards wrote: There is drag. You are also riding with an extra 5-10 lbs of equipment underneath.
Alright, Thanks.
