Hello,
I have a Problem with a Prophete Pedelec. The Components are from Bafang. The Display says "08" after turning on. The Controller is a CR S10R36 (very small) and the Hub Motor is a GM350.250.D". I think this are Prophete specific Names and also the Display seems to be special.
The Manual says Errorcode 08 has something to do with the Motor.
What I have checked until now:
- The Pedal-Sensors LED lights up when turning. And I can measure a signal with a multimeter.
- The 3 Motor-Windings has something under 1 Ohm
- With 5 V to the Motor, the 3 Hall-Sensors have 3V output. No changing by turning the motor.
What else can I do? I can not find any documentation about the motor or controller or any spare parts.
Best regards,
Hoelgi
Best regards,
Hoelgi
