Ok I recently purchased some 4mm bullet connectors and 10 gauge silicone wire to go along with my turnigy lipos that also use 10 gauge wire. Normally you would slide the plastic part of the connector over the wire and solder on the metal part of the connector. Well I am running into issues with this 10 gauge wire... The wire seems too big for the connectors. It will not slide through the plastic cover and the acceptance that the stripped portion of the wire would normally slide into to be soldered does not fit. I know the simple solution would be to get a smaller gauge wire but i don't want to because 10 gauge is what my batteries leads are. I am looking for tips, tricks, insight, or magic to help me solve this dilema. Do they make 4mm bullet connectors specifically for 10 gauge wire? My connectors and wire are from epbuddy.com and I can't find any info on what gauge wire is reccomended for them.
