ElectrifyAllStuff
100 µW
My current electrical setup is as follows.
“E-bike”:
-72V 25Ah 1800 Watt-hours
-Phaserunner L10
-V3.1 Cycle Analyst
-Grin All-axle front hub
-E-brake levers with micro switch
Lighting (12V):
-DC/DC Converter
-ON/OFF toggle switch (for the 12V output of the converter so that the entire light/accessories circuit can be toggled on and off)
-Main Control switch (DTR/Headlight toggle, left and right blinker independent toggle, horn)
-x2 Headlights
-x4 LED light strips (x2 left blinker and x2 right blinker)
-x1 Brake/tail turn light (DTR, left and right blinkers, and brake)
-x2 LED flashers
-x1 OPTO Isolator (to control the brake light with micro switch signal)
The OPTO Isolator I am using is the CX240D5 and the technical info is at:
I am a very much out of my element and haven’t touched low voltage since middle/high school and am a little rusty. I have everything working except the brake light. For some reason no matter what I try I can’t seem to be able to sort out what I’m missing. Please correct me if I am wrong at any point!
Below is a “schematic” I tossed together to get the general idea.
![IMG_0020.png IMG_0020.png](https://endless-sphere.com/sphere/data/attachments/196/196679-aa239d3a51d3db478d7e01a03da5388e.jpg)
The current brake micro switches are 0-5V active high. By using the OPTO isolator it’s keeping the 12V and 0-5V circuit separate; therefore, allowing the 0-5V e-brake signal to safely be used to control the 12V brake light.
The active high status of the e-brake 0-5V signal with this OPTO relay work as it has a zero voltage turn on. Knowing the 0-5V e-brake signal doesn’t have enough current to supply the OPTO isolator it would require a pull up resistor to be able to supply the correct current for operation. (~200-330ohms)
I have tried to wire this relay up every which way from Sunday and I have not been able to get it to work. I had thought given the constant feedback I was getting on the Cycle Analyst screen that I must have had a ground fault going from bench test to wiring it up on the bike (relays were still stuck in shipping so I decided to wire it all up on the bike except the brake light line and relay, ahead of time).
I’ve cut into my harness and I’m now basically back to a bench test to eliminate the possible ground fault. Still not success. I currently have my 12V accessory switch and Main Control switch hooked up to the flashers and the rear brake/tail lights (which will allow me to test all but the horn which I know already works).
Without the relay in everything works perfectly just the way it should. As soon as I try to hook up my control side of the relay I get increased brightness on my CA and not the correct function or voltages at the relay terminals and brake LED.
I assume I must not being installing the pull up resistor properly. Given I have the v3-CA I just took my 5V off the unused pin of the e-brake plug. I did read in another old thread/post about someone pulling off of the Aux or Throttle Control lines, I tired that too and I am getting the same results.
Can someone, anyone please help me make my brake light work! =D
“E-bike”:
-Phaserunner L10
-V3.1 Cycle Analyst
Lighting (12V):
-DC/DC Converter
-x2 Headlights
-x2 LED flashers
