bikein11212
Hi i swapped the bearings and wires in my hub motor an didnt have a replacement hall sensor board so i removed it and soldered the phase wires properly then closed it back up.
At first the motor ran fine off the ground now i try run in on the ground it stutters back an thorth an cuts out.
Now after this trying to run off ground the motor stutters same as on the ground.
The controller is ok as tested 2 an bith same result but work fine with my other bike
Note it ran fine till put on ground eny help would be much appreciated thanks
