SniperGaulois
I set fire to a a Sanyo cell from 2018 in a controlled environment, I melted through the steel using a 100A current, by placing some battery terminals on either side of the negative terminal. The battery flashed as the steel and copper vaporized, and then it started burning the lithium inside. It was burning in the same way as plastic inside the battery with a small resiliant flame on top, no sparks and runaway blaze. I put it the flame out by blowing on it or using a rag, and after a while it went cold, revealing transparent electrolyte gel and a gap in the battery shell.
I don't recommend this test for old batteries because they are too explosive, but it can be fun for people that want to check about flammability of the most recent models.
It would be good to have a standard test to vaporize a zone of the battery shell, please give results if you have time for it.
