You can do that, but the result will be a slower bike speed.Deesjoint said:Hi. I was wondering if a have the 2 speed motor that's for the 26" rim and put it on a 24" rim will my speed be increased. Thanks.
That's right. He had a lot of trouble communicating with them. They are trying to develop bigger versions and narrower ones, but there's nothing iminent, unfortunately. Not a lot came from the meeting. It was just a repeat of what we already know.leelorr said:Dv8eh,
A few weeks ago I think you mentioned that you knew someone that was going to see the factory reps and that they would ask if there any plans for a higher wattage motor coming out. Have you heard anything?
I don't think it would mke any sense to do that. This motor is an alternative to a mid drive. What it's good for is to get you round at speeds up to about 20mph while pedalling. Then, when you get a very steep hill, it can use the low gear to winch you up at low speed. It can go right down to about 4mph and still be relatively efficient when climbing. The 36v one at 15A can get you up a 25% hill with a bit of pedalling. The 48v one can do 30% and more. That's with a 100kg rider. If you're lighter it'll perform better.craiggor said:Any thoughts of the advantages/disadvantages of using the xiongda as a mid drive.
Agreed....although the retro-direct concept would works perfectly even for middrives, the XD is not the right motor for that.....it would make no sense to put a 3+Kg hubmotor of that low power like the XD as midmotor.d8veh said:I don't think it would mke any sense to do that. This motor is an alternative to a mid drive. What it's good for is to get you round at speeds up to about 20mph while pedalling. Then, when you get a very steep hill, it can use the low gear to winch you up at low speed. It can go right down to about 4mph and still be relatively efficient when climbing. The 36v one at 15A can get you up a 25% hill with a bit of pedalling. The 48v one can do 30% and more. That's with a 100kg rider. If you're lighter it'll perform better.craiggor said:Any thoughts of the advantages/disadvantages of using the xiongda as a mid drive.
Oh no, that's tragic, I hope it can be recovered.docnjoj said:Here is the end. I was sent a plastic bag of thick white goo in the parts package which I thought was thick grease. I stuck the stuff in the gears about to close up the motor, but it does not feel the least bit slippery. Could it have been sealer? That would end this project. It is a shame cause I really like the motor.
otherDoc
cwah said:Anyone tried to feed 48V 20A on this motor? I'm doing this on my q100H and it's great. But sometime I'd like more torque.
A bit more torque and keeping the 25mph max speed I have from my q100H would be perfect
'it's complicated' I have a 12s 36v liFe pack (these sit @~ 39.6v) and I sometimes add a Lipo (1s) in series for a speed boost (an extra 3.8v or so)cwah said:42v battery? how many s? If I use 48v battery on 36v controller it'd just blow I suppose?
menvert said:Oh no, that's tragic, I hope it can be recovered.docnjoj said:Here is the end. I was sent a plastic bag of thick white goo in the parts package which I thought was thick grease. I stuck the stuff in the gears about to close up the motor, but it does not feel the least bit slippery. Could it have been sealer? That would end this project. It is a shame cause I really like the motor.
otherDoc
The 48v setup should be able to achieve that with the right windings. With a 36v setup ramped up that much, I think it wouldn't last so long.
You'd then be able to do something like 12mph in Low, but I'd suspect 25mph on anything except flat is a bit optimistic, I get about 31mph on flat when I use my approx 42v battery on a 36v 15A setup.
Of course it all depends on many factors - weight, windings, how much you pedal PAS or accel.
menvert said:'it's complicated' I have a 12s 36v liFe pack (these sit @~ 39.6v) and I sometimes add a Lipo (1s) in series for a speed boost (an extra 3.8v or so)cwah said:42v battery? how many s? If I use 48v battery on 36v controller it'd just blow I suppose?
Under moderate load tends to be about 42v whereas a 48v 13s Lipo (from my research, I don't have one) will run between 48.1 and 54.6v depending on the discharge
Edit: Ah yeah, when I suggested the 13s 48v LiPo on a 36v controller people on this thread did suggest it's likely to kill the controller, but will probably be okay with a 12s lipo
