Jamil.Siddiqi
- Joined
- Mar 19, 2019
- Messages
- 31
I also ride in a very puncture rich area. Here my current findings:
going from bicycle to MC tires helped a bit, but not too much. The typical thing over here are nails, construction staples, screws and bolts.
If you want to be 100% puncture proof, you could try mousse in MC tires. Rolling resistance is horrible, so is the weight, but 100% puncture proof. It added 5-6kg per wheel (rim, tire + mousse together) compared to bicycle wheels.
My current setup is with Continental KKS10 tires and the Tubliss system. I had one puncture so far - on which I was able to ride home. Added some slime and voila everything sealed. Less than 5 minutes to fix and it has kept the pressure for 2-3 months now. Without tubes the slime works much better. The tires get sealed much more easily, since they don't expand like soft tubes.
Weight is less than the mousse and the rolling resistance is much better as well, since you can use higher pressure (mousse behaves like 15 psi or so).
