RyanC
Hey All-
New here and recently got into ebikes with a Radwagon, and have been pretty happy with it and enjoying riding/commuting by bike a lot. The main thing I would like to change is to get a longer range, but I also would really like more acceleration and climbing speed. After reading up a little and poking around the for sale section here I'm thinking that I might be able to buy a slightly used battery and geared front hub motor and possibly kill two birds with one stone for close to the same price.
So the idea would be to end up with the stock system generally in PAS1 mode only, and then use the front geared motor only with a throttle and it would have it's own controller and battery. My wife has a throttle only Hebb 500 with a 36v Ezee, it seems like if I added that to what I have it would be great.
Here are the main questions I have-
-I understand (from em3ev) I can use the stock tektro brake levers to both controllers but I have to wire both of the controllers negative to the batteries together. I'm no EE, but I can probably figure that out, just a jumper cable going from one negative lead to another (large enough cable not to get hot)? Anything to look out for here? Or any easier way to do it (2nd set of brake sensors?).
-What motors do people think would work best here? Would I benefit much from the higher torque options like a 10 or 12T mac? Or would even the faster q128 probably be a good boost (is there a front disc option)? I'm not doing any crazy steep climbs, some short %5-8 and some 2mile %2-3, acceleration up to 25mph would be nice though.
-Is this a decent plan? I also am debating a larger ~15Ah battery for the stock Shengryi and using the stock battery for the front motor...Any thoughts or experience would be appreciated. Thanks!
