Formation charge on LFP can be that high, but that's a factory thing. Sellers mistake that in the data sheet for the end-user charge limit sometimes and so put hte wrong voltage in their ad, but since they dont' usually have the datasheet on the sale page the end-user can't tell that.
Most sellers appear to have no real idea of what they are selling, and no real info on it, especially on sites like Ali*, Ebay, Amazon, etc. Makes it tough for an end-user to find what they want unless they already know about these things and can research on their own....
The other problem with this is that since the sellers in those cases don't really know what they have, they may also not ship the correct items (may even have a different item than an ad in their warehouse and not know it).
These problems apply to all products, not just batteries and whatnot. :/
I have not seen these specific ones. I couldn't find a proper spec sheet on the page linked previously, only this page from a spec sheet listing a few of the various specs (no charge/discharge/lifetime curves or testing parameters, etc).
It does point out a few things that might be important.
They're only 31Ah at 1C, or 31A. So if you use them at higher currents you won't get the full capacity. How much you lose, you'd have to test, because their spec sheet doesn't have this info. It just says they can be used at up to 4C 124A, with a burst of unspecified length at 10C 310A.
It also doesn't say what happens if you charge them at more than the standard charge of 1C (31A), it just specifies that they could be charged at up to 3C 93A.
It certainly is...and it should also be more reliable because of the fewer connections to fail.
Just ensure that the cells are all supported by (and different parallel groups separated by each other with) a frame and not the interconnects, so that vibration, etc does not stress the connection points either inside or outside the cells. See various Headway builds for pack build methods and precautions (they are assembled the same way).
